Late Incoming Call (X00TD/ZB602KL, ZENFONE MAX PRO M1)
After 429 update of Android 10 developer version, every incoming calls rings after a duration of 4 to 5 seconds of the actual call placed by the other side!!
0
Comments
Try to clear cache and then check
Stop pretending moderator and use some logics
It's related with the OS not about app caches
Bro if u haven't clear your cache since a long time then your phone will be laggy and may be u feel little bit slower and it will fillup your storage also. Everytime its not only about OS. Sometimes try to do some basic things which can solve your problems. If u don't want to try then it's ok.
Peace☮️
Did you try to understand what's the issue??
It's the call incoming notifications which comes late as 4 seconds after any call being placed from any other device.
Hi dibyarupprk2011,
Did this behavior appear in previous versions?
If possible, could you show us a short video? Does it appear when receiving a call from different persons?
No, it's only in version 429 and i can't provide you video as i have downgraded for this issue..
It's from every caller not only a specific.
I have tried calling from other devices and saw that a total of 5 second delay the incoming call notification comes which has answer or reject options
