[ZenFone 3 Max ZC520TL] phone not recognizance USB stick
DragutuDragutu Level 1
edited September 2020 in ZenFone Max Series
  1. Model Name: x00d (ZC520TL)
  2. Firmware Version: NRD90M.WW_Phone-14.10.1808.119-20180803
  3. Rooted or not:not rooted
  4. Frequency of Occurrence:
hi,
i try to connect in phone one usb stick( 16g formatted fat32) but in File Manager not see.
usb stick in another device ( asus PU24- one tablet) is recognize. i transfer from/in Usb drive.
how is made?
Comments
  • edited July 2020
    Hi Dragutu
    Thank you for your asking. Are you asking phone-USB cable-PC issue? Kindly try some stay-at-home troubleshooting tips below:
    1. Check your USB Preference settings
    Settings>Connected devices>USB>file transfer
    2. Make sure that the USB configuration fits your device
    3. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
    4. Please try "the Factory Reset"
    Settings>System>Reset options>Erase all data(factory reset)
    Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
