home screen icons display problem
- Model Name: zenfone 5
- Firmware Version:
- Rooted or not:not rooted
- Frequency of Occurrence:2-3 days
- APP Name & APP Version (If your issue relates to the app):
don't know what happened, my home screen is displaying like this , but i got no problems with my lockscreen though, i checked my app size or font sizs every thing looks default, and i also checked in themes application , the settings are default. so now how can i get it back to normal , can anybody please help?
Comments
the home screen looks like this!!!!
doownload nova launcher, apply and delete.
Hi davil
Thank you for your asking. Kindly provide the information below so that we could better assist you.
1. Your current firmware version
Settings>System>About Phone>Software information
If you try to update to the latest version, does the issue still remain?
2. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
3. Also, please try "the Factory Reset"
Settings>System>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
Hi Davil
settings> Advanced > special modes> turn off the Easy mode slider.
