Sound quality degraded via earphones after 429
Sound quality degraded a lot.. There ia no bass at all.. I use earphones a lot.. This is a big problem for me.. And i have doubt that can I use the official downgrade file to downgrade from 429 to pie 060? It works for 424 but will it work for 429 also.. If anybody tried please give the response
0
Comments
Hi ambeerrajeshwarrao9849,
Sorry, we've checked with relevant teams about the sound quality. In the meantime, if this is affecting your normal use greatly, you may choose to downgrade. You can find the file and instructions in the description "Version MaxProM1_downgrade_to_9": https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB601KL)/HelpDesk_BIOS/
Thanks for your understanding.
