About overheat device heating issue in regular use, we suggest that you avoid running apps that may use much memory for a long time, for example, 3D games and video.
Also, it's recommended that do not use your phone/tablet while it is charging.
Please also try removing the background apps in recent app list, and check again.
Comments
Hi GAM3CRACK,
Please also check if this behavior appears in safe mode: https://www.asus.com/support/FAQ/1005163/
For more information on improving the overheating behavior: https://www.asus.com/support/FAQ/1011555/
