Wireless ADB connection is inconsistent on Zenfone 5 Android 10 Beta 3
- Model Name: ASUS_X00QD
- Firmware Version: QKQ1.190723.002.WW_Phone-17.0615.2005.25-20200604
- Rooted or not: Not rooted
- Frequency of Occurrence: Always
- APP Name & APP Version (If your issue relates to the app):
Steps to replicate:
- Bind your device with `adb tcpip 5555`
- Connect with `adb connect YOUR_IP_ADDRESS:5555`
Actual Result: `failed to connect to '192.168.0.11:5555': No route to host`
Current workaround:
Re-enable Wifi and command `adb connect` again
While cable-based ADB is working
Comments
Hi johncyrillcorsanes
Thank you for your asking. Kindly provide the information below so that we could better assist you.
1. Have you ever unlocked or rooted your device before?
2. Could you use the wireless ADB before? Does the issue appear after any system download or update? If it did appear after system update, which version?
3. Could your cable-based ADB always work, no matter which firmware?
After investigation, the tech team confirms that the wireless ADB could be operated properly. Kindly check if the device is linked in the same domain. Thank you.
