Numeric pad does not lock as a numeric pad on my Zenbook Pro Duo
amgasvfxamgasvfx Level 1
edited September 2020 in ZenBook
  1. System:
  2. Battery or AC:
  3. Model:
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
Detailed description:When activating the numeric touch pad . any pressure on the illuminated keys and the pad deactivates to change back to a track pad.
Comments
  • LiviuLiviu Level 2
    edited June 2020
    There is something wrong with yours. I tried on mine and if I slide my finger on the pad, it does move the cursor, but I can still insert numbers. So, it's like 2 in 1 at the same time. When I have it on trackpad mode, it works only as a trackpad, no interference. So, everything is running normal on my side. You should fill the small form from your post with all the details.
  • Hello amgasvfx,
    May I have a video record of the issue?
    Please kindly check if your BIOS and drivers are up to date.
