Max pro M1 stuck in bootloader
- Model Name:m1
- Firmware Version:
- Rooted or not:no
- Frequency of Occurrence:whenever I press power button
- APP Name & APP Version (If your issue relates to the app):
Automatic emergency 112 dialing
Phone turns off at Asus logo
Earlier..recorded fingerprint vanished
Bluetooth turns on automatically
Heating way too much
Comments
Hi there, kindly check if you can perform the below functions:
Rebooting to bootloader
Step 1. Switch off the device by pressing the Power button for a couple of seconds
Step 2. After that hold down Volume Down + Power keys together for a few seconds
Step 3. Release power key and keep pressing volume down button, you will be then be taken to Recovery mode
Step 6. In recovery Mode go to Reboot to Bootloader by scrolling down/top with volume button
Step 5. When Reboot to Bootloader is selected then press power key to confirm option
Option 2: Performing hard reset(data backup is necessary)
2. When the device is off, press (also hold) volume down key and then press (also hold) power key.
After the device vibrates, release the power key (keep holding volume down key) to enter recovery mode.
3. Select "wipe data/factory reset" by volume down key (or volume up key), and then press the power key.
4. Select "Yes -- delete all user data" by volume down key (or volume up key), and then press the power key to start reset.
5. After the reset is completed, select the "reboot system now" and press the power key to reboot your device.
I wasn't able to do the step 1 .. phone turns off quickly
I kept tapping on the screen to log in to my device
Now using it without touching the power button 😏
I seems that it's not just me who is facing this issue ..can you clearly explain what is causing this ?
Victor common buddy do something about this issue. A hell lot of users are facing this same issue and it is evident that it is due to your buggy update. You are a multi-national company at least show some professionalism. If you are not able to fix it atleast own up to the problem.
when i try to do hard reset menu it automatically shutdown
