Network signal notification problem in ASUS ZENFONE MAX PRO M1
I got network signals. But quick notification panel shown No service..
I tried safe mode , wipe cache partition, data factory reset..
But not solve this problem.
Comments
Hi [email protected],
Do you have one or two SIM card inserted?
Do you mean it is working normally but shows no service?
Please show us a screenshot of Settings>Network&Internet>Sim Cards.
Thank you. 🙂
Hi VEL ASSA,
Sorry for our late reply. Is this problem still appearing? If yes, could you tell us your current firmware version? (Settings > About phone > Build number)
Do you mean it is working normally but shows no service like the first screenshot?
Build no.429
Yes, Working fine. but show no service in status bar down
Why you are buy bsnl or Idea sim in my devices jio sim work normal
Problem in device not in network.
Bsnl call waiting settings switches are not working properly.
Call waiting problem faced in previous beta.
But not check in with this latest update
try to remove & inert sim cards or changing sim card, if this helps your problem.
