Battery charging problem
saurabhbhola80saurabhbhola80 Level 1
edited September 2020 in ZenFone Max Pro Series
  1. Model Name: ASUS_X00TD
  2. Firmware Version: Build number PKQ1.WW_Phone-16.2017.2005.082 20200506
  3. Rooted or not: Not
  4. Frequency of Occurrence: All time
Battery charging takes too much time to charge with original charger
Comments
  • Hi, we'd request you follow the below steps:
    1. Clear system cache.
    2. Try the same under safe mode:
    Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
    3. If still you face the issue factory reset your phone after taking a full backup.
    4. Last option would be to visit the service centre to have
    a check. Locate here: https://www.asus.com/in/support/Service-Center/India
