Fingerprint sensor problem
I had found a bug in fingerprint on the asus zenfone max M1. The fingerprint lock screen adding option is missing and also the fingerprint sensor is doesn't working. This problem is arrived on a few days after the latest security patch system updation.
I had tried solve the problem by doing factory data reset. And doesn't worked. You are want to fix this problem new software update.
By your customer
0
Comments
I'm facing the same problem right now.
