HDR not working on GCAM for Max Pro M1
Have been facing this issue with every GCAM mod I have used
The HDR and HDR Enhanced options don't work
When I click a picture, it shows this and a minute later a non-HDR image is saved
Along with this problem, the potrait mode also does not work
Non-HDR works fine
Does anyone have a solution to this problem?
Device : Zenfone Max Pro M1 (6GB) (Camera2Api enabled)
Current GCAM mod: MGC_7.3.020_Parrot043_V6
Comments
I cannot download gcam in my Asus zenfone max pro m1... It says your device isn't compatible.... Any solution please...
You have to enable Camera2Api first
Same problem in my mobile Asus Zenfone Max Pro M2 after installing android 10 AOSP . Gcam HDR+ processing Stuck. Please give me some solutions.
You cannot download gcam from play store.
