Comments
  • Hi floryn_rooney96
    Thank you for your asking. Kindly provide the information below so that we could better assist you.
    1. Model Name: Settings>System>About phone
    Refer to the link below to check the model name by model no. in the link
    https://www.asus.com/support/FAQ/1014441/
    2.Your current firmware version
    Setting >System>About Phone>Software information
    If you try to update to the latest version, does the issue still remain?
    3. Does the issue appear after any system or apps update/download?
    4. Have you open location permissions in apps?
    Settings>Security & lock screen>Location>App-level persmissions>turn on the permission of the app you want
    Furthermore, remember to turn on the "Location" (swipe down Quick Setting area).
