Max M2 Battery draining issue after A10 beta update
edited September 2020 in ZenFone Max Series
I updated the new A10 beta version for Max M2 yesterday. Everytime i am restarting my phone then the battery is draining so fast . Showing 45%per hr draining speed. i already reseted my device 2 time's and cleared cache. Sometimes charging good and sometimes slowly . Help me out.
Comments
  • victor010victor010 Level 5
    edited June 2020
    Please follow below steps may improve battery backup:
    1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
    2. Adjust sleep time and brightness (Settings > Display)
    3. Boost memory when you see memory consumption is high with no app running,
    4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
    5. Check the following article for more information: https://www.asus.com/in/support/article/604/
    Recalibrate battery
    To recalibrate battery, charge your phone to 100% without interruption.
    then discharge it normally till 0%(phone gets switched off).
    charge it to 100% in switched off condition and keep it in that state for a little more time.
    now switch on your phone in charged condition and unplug when ASUS logo appears.
    keep the phone unused for 5 mins.
    you will get far better battery life as the battery stats.bin file will be updated.
