max pro m2 android 10 bugs in .424 build
I just updated my phone on 27 may at 8:30 PM
- ui is so smooth and much better i thing ui is amazing
- navigation gesture working fine,
- battery backup is also fine or i can say impressive,
- dark mode is also nice,
- eis is also working fine,
- device is certified,
- pubg has hd high graphics
bugs
- slow charging (very dissapointing it takes more than 4.5 hours to charge from 1% to 100% but is pie it takes only 2.5 hours)
- round corner is missing
- ringing and notification sound is low
- in speaker there is no bass and sound is also low little bit
- and the suggestion from setting is not removing
- notification light blinks sometimes green sometimes yellowish white
features we want
- google assistant ambient mode
- call recording feature in phone app
Comments
Hi gbun,
We've replied you in this thread: https://zentalk.asus.com/en/discussion/29212/max-pro-m2-beta-2-bugs
>Thanks for your suggestion, we've collected this suggestion and forwarded to relevant teams. This idea will be taken into consideration as a future design.
