How do I fix my Asus ZenFone battery draining problem?
Ameena
Hello
I have the Asus ZenFone 3 (ASUS-Z012DB) the battery drain 2% every minute just when the screen is on and no application is running. I don't know what the problem is but this really annoys I have to charge it so frequently.... I have checked for ways to increase the battery life but that doesn't help.. This is a graph of the battery consumption
Please help me fix this problem.... 🙏
1 ACCEPTED SOLUTION
Accepted Solutions
victor010
Zen Master III
Please follow below steps may improve battery backup:
1. Enable “Power saver” (Settings > Power management)
2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
3. Adjust sleep time and brightness (Settings > Display)
4. Boost memory when you see memory consumption is high with no app running,
5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
Recalibrate battery
To recalibrate battery, charge your phone to 100% without interruption.
then discharge it normally till 0%(phone gets switched off).
charge it to 100% in switched off condition and keep it in that state for a little more time.
now switch on your phone in charged condition and unplug when ASUS logo appears.
keep the phone unused for 5 mins.
you will get far better battery life as the battery stats.bin file will be updated.
victor010
Zen Master III
Recalibrate battery
