Battery issue
kingpiyushdurej
Model Name: Asus zenfone 5z 6gb
Firmware Version: don't know but has March security update
Rooted or not: not rooted
Frequency of Occurrence: regularly
APP Name & APP Version (If your issue relates to the app
The main problem is with battery ,with the latest update battery drain out very quickly in normal use
Sometimes fast charging doesn't work sometimes it doesn't recognise the charger heating issue is also very common
43 REPLIES 43
drreeteshsah
Ausu 5z The main problem is with battery ,with the latest update battery drain out very quickly in normal use
hkorkut
Rising Star II
this is a common problem for too many zenfone 5z users. we now expect a clear and precise solution.
BrunoF20
Zen Master I
Settings
Applications and notification
Show all (number of) apps
"Three dots" (in the top right corner)
Show system apps
Find and deactivate:
Facebook app installer
Facebook app manager
Facebook services
[Edited in 24/05/2020 20:00: Those three are just telemetry apps.]
Yes, those are there even with all of the Facebook apps uninstalled.
Also, I advise you to tweak Device manager and PowerMaster (both are under Settings>Advanced>Device manager).
hkorkut
Rising Star II
Can you give details about device manager and power master? How and what should we do?
