Problem in Max Pro M1
Pubg not working properly hd graphics not available
Heating issue
Battery draining
Brightness level very low
1
Heating issue
Battery draining
Comments
Hi dinkarks321,
Pubg not working properly hd graphics not available:
Please provide your firmware version: Settings > About phone > Build number.
Heating issue: About overheat when gaming, and device heating issue in regular use, we suggest that you avoid running apps that may use much memory for a long time, for example, 3D games and video.
Also, it's recommended that do not use your phone/tablet while it is charging.
Please also try removing the background apps in recent app list, and check again.
Please also check if this behavior appears in safe mode: How to Enter and Exit Safe Mode on Android phone ? | Official Support | ASUS Global
For more information on improving the overheating behavior: https://www.asus.com/support/FAQ/1011555/
If the problem still appears, please tell us:
Battery draining:
Is the battery drain problem appearing in use or sleep mode?
To monitor the battery usage, please go to Settings>>Battery>>More>>Battery usage, and stop or reinstall the high battery usage apps.
These are our suggestions to improve the battery drain problem: https://www.asus.com/IN/support/FAQ/1041741
These are our tips to maintain a healthy battery using habit: https://www.asus.com/in/support/FAQ/1009546
If your phone is over one year of use, you may go to service center to check the battery health (life cycle remain), and check if replacing a new battery is needed.
Brightness level very low: At which brightness level is it low?
Thank you 🙂
Hi dinkarks321,
Please check your inbox for a message I have sent you.
Thank you 🙂
Hi dinkarks321 ,
An updated Android 10 version WW-17.2017.2006.429 has been released.
PUBG HD & high frame rate had been added.
You may manually download from our website: https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB601KL)/HelpDesk_BIOS/
Thank you and have a nice day 🙂
