Updated Intel Management Engine Interface WHQL Driver 2013.14.0.1529 Dated 24-03-2020 on 14-05-2020
- System: Windows 10 64Bit 2004
- Battery or AC: Both
- Model: X542UQ.309
- Frequency of occurrence: Nil
- Reset OS: No
- Screenshot or video: Yes
Detailed description:
On 14th May 2020, I updated Intel Management Engine Interface (MEI) Driver Version 2013.14.0.1529 WHQL on windows 10 64bit 2004_19041.264.
Also, I updated Intel Management Engine Firmware v11.8.77.3664 on 30-04-2020.
Moreover, i enabled spectra vulnerability fix by registry keys. Those registry keys are available in support.microsoft.com.
Here are links
for spectra fix guidance for windows client os
spectra fix guidance for windows server os
I taken high risk for updating latest firmwres and drivers because of intel indentified the vulnerabilities in management engine firmware.
I downloaded Intel Management Engine Interface driver from below website.
NOTE::
This version 2016.14.0.1555 includes Intel ME interface driver 2013.14.0.1529, Before downloading and installing in your laptops or desktop, Check with your computer manufacturer support website.
I am not responsible for the inconvenience caused due to unbootable or BSOD errors or any problems.
And I took the risk, and updated myself, i know what i am doing and how to solve the problems.
the source is taken
https://www.station-drivers.com/
Thanks for reading my post. If you like means then give UPVOTES to me.
