Incoming call notification does not show on screen. I'm using Asus ZenFone Max M2.
- Model Name: ASUS_X01AD
- Firmware Version: Android 9, Security Patch Level 5th March 2020
- Rooted or not: Not rooted
- Frequency of Occurrence: Always
- APP Name & APP Version (If your issue relates to the app): Android systen app
I can not see incoming call notification screen where I can receive the call or reject.
Every time when there is an incoming call, I have to unlock the screen and pull down the notifications and receive the call from there. It's very annoying. I have updated system software but the problem is not resolved. Please help.
Thanks
0
Comments
Hi there, you may click on the following link to download the latest update manually, request you to read the instructions before upgrading and take a full backup of the device before. Click here: https://www.asus.com/in/Phone/Zenfone-Max-M2-ZB632KL/HelpDesk_BIOS/
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue factory reset your phone after taking a full backup.
