How to get recovery mode in MAX PRO M1
- Model Name: X00TD
- Firmware Version: QKQ1.WW_Phone-17.2017.2004.424-20200414
- Rooted or not: NO
- Frequency of Occurrence: ALWAYS
- APP Name & APP Version (If your issue relates to the app): RECOVERY MODE
HOW TO GET RECOVERY MODE IN ASUS ZENFONE MAX PRO M1 ANDROID 10.
I tried through HOLD the VOLUME DOWN + POWER KEY .
The logo showed then phone go to black blank screen.
How to slove this problem.....
0
Comments
Try again sometimes it doesn't work..
I tried more times........
But not working.....
All is well but sep endpoint mobile security says restore the device to stock firmware.fix it.
Sep endpoint mobile software says restore the device to its stock firmware
Fix it
When I updated android 10 then it is a trouble , screen shot is given
