Heating issue and battery drain
- Model Name: Max Pro M1
- Firmware Version: WW_Phone-16.2017.2004.063-20200407
- Rooted or not: No
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
After last two updates my phone has severe heating issue, the phone seems to always has high temperature regardless of any background app's, and battery is also draing fast. what to do next please suggest.
0
Comments
Please follow below steps may improve battery backup:
1. Enable “Power saver” (Settings > Power management)
2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
3. Adjust sleep time and brightness (Settings > Display)
4. Boost memory when you see memory consumes is high with no app running,
5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
6. check for latest ZenUI/3rd party Apps update.
