Low sound in ear speaker since 10 months
- Model Name: max pro m2
- Firmware Version:4.4.153-perf+#1Tue April 7
- Rooted or not: not rooted
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
0
Comments
Hi sfarshi91,
Thank you for asking. Please provide me your current firmware version:
Setting >System>About Phone>Software information>Build Number
If you try to update to the latest version(WW-16.2017.2004.075), does the issue still remain?
If the problem still appears in the latest version, please tell us the app name and steps you performed.
Ya i am using last security update but till now my ear speaker sound very low plz fix it very soon as possible thanks
Hi sfarshi91
Please try to clean the earspeaker and check if any item (e,g. glass screen protector..) has cover the earspeaker.
Also, do you feel sound low while calling or any other function? Does this happen to the preloaded calling app or third party apps? If it happened in app, please provide us the name and version of app.
Please provide the whole screenshot of "Sound"
Setting>Sound
Low sound in ear speaker since 5 months
Hi vikky
Thank you for your asking. Kindly provide the information below so that we could better assist you.
1. Model Name: Settings>System>About phone
Refer to the link below to check the model name by model no. in the link
https://www.asus.com/support/FAQ/1014441/
If your device is not ZB631KL, please open a new thread your own.
2. Your current firmware version
If you try to update to the latest version, does the issue still remain?
3. Does the issue appear after any system/apps download or upgrade?
