Aerocooler fan 3.5mm Microphone Problem
XiiSharkzXiiSharkz Level 1
edited September 2020 in ROG Phone 2
I use aerocooler fan 3.5mm with earphone . Now I got problem , didn't know if is a bug or hardware issue .
When I use 3.5mm port with the fan , the sound came out ok but the microphone aren't working . If I use the normal 3.5mm port on the bottom of the phone , the mic work just fine .
I do really need this help since I am a Facebook streamer . I need to solve this problem fast . I can't use earphone at the bottom since I played PUBG mobile with airtrigger frequently.
Do I need to hard reset or downgrade back to A9 ?
@Anders_ASUS
Comments
  • Game Genie settings -> Live stream -> Live audio source, make sure that it's set to 'Microphone'.
