Battery not charging to 100% and discharging fast and be heated
BABUSONA
My Asus zenfone max pro M1 mobile phone isn't charging to 100% ,it stuck at 99% and heat generated in backside, and battery discharging fast.
victor010
Zen Master III
Hi, we'd request you follow the below steps:
1. Check for the latest firmware. Click here: https://www.asus.com/in/Phone/ZenFone-Max-Pro-M1-ZB601KL/HelpDesk_BIOS/
2. Clear system cache.
3. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
4. If still you face the issue factory reset your phone after taking a full backup.
