Idle time battery drain
a.m.plabona.m.plabon Level 1
edited September 2020 in ZenFone Max Pro Series
ZF Model: ZB602KL
RAM: 6G
Firmware/APP Version: .057
Frequency of Occurrence: Normal
Rooted: No
APP Name:
After getting August 2019 update via OTA, I'm facing hugh idle time battery drain.
Screenshot attached.
Any suggestion to reduce idle time draing ? ?
Comments
  • Hi a.m.plabon
    Can you provide some information and screenshots regarding the battery drain issue?
    Please charge your phone to full before going to sleep, and leave it unused and unplugged overnight. Please capture screenshots as below on the next morning before you use your phone and tell me how many percentage of power the phone has consumed overnight
    1. Battery: settings> Battery (Device usage since full charge)
    2. Battery usage: settings> Battery> click the three dots > battery usage>show app usage
    Thank you:)
  • Selena_ASUS posted on 2019/9/6 08:57
    Hi a.m.plabon
    Can you provide some information and screenshots regarding the battery drain issue? ...
    Dear Selena,
    As per your requirement, kindly check the attached screenshot.
    Thanks
