Navigation problem
Model: ZE620KL
RAM: 6G
Firmware/APP Version: 90.11.162.88
Frequency of Occurrence: Continuously
Rooted: No
APP Name: Software
Screenshot: https://us.v-cdn.net/6031231/uploads/ww_attachments/201908/03/140526w19y06orm9fa2amm.jpg
Hi, I'm facing an bug while using pill style navigation bar when i swipe up for the recent application then there is flickering then icons go up it look very bad i am facing thus bus from 2 month i was hoped everytime that next time it will be fixed but no it is not ☹️ so please fix this simple bug
Blake_ASUS
Community Legend II
Hello bobybhangu1047, May you tried to enter safe mode and see if there is the same issue? https://www.asus.com/support/FAQ/1005163/ Have you tried to do factory reset before? Is it possible to record a video to see how is the flickering appears? Thank you so much.
