WiFi hotspot will not work
Model: ZE620KL
RAM: 6G
Firmware/APP Version: 90.11.162.72
Frequency of Occurrence: Ongoing
Rooted: No
APP Name:
Screenshot: https://us.v-cdn.net/6031231/uploads/ww_attachments/201906/29/103602tlbwvnmbr4rppene.jpg
Hi, I cannot get my laptop to access the internet through my Asus ZenFone 5z via wifi, usb or Bluetooth. Can someone help please,? Thank you.
ServiceE_Asus
Hello flashfire.cypher, Good day. Does this problem appear under the safe mode? In safe mode, only the factory pre-installed applications will be loaded. For instructions, please refer to the link below: http://www.asus.com/zentalk/forum.php?mod=viewthread&tid=3105&highlight=safe%2Bmode Please also help me reset the network settings for a check. (settings> reset uptions> reset WiFi, mobile & Bluetooth) Thank you.
LegacyUser
What to do if my connection isn't stability
ServiceE_Asus
Last edited by Emilee_ASUS on 2019/7/5 16:11 Hello dornkol, Good day. Do you mean the hotspot connection is not stable? If yes. Is there another device nearby that you've ever connected? I would suggest you can try to reconnect it again. Thank you.
