Battery
ZF Model: ZE554KL
RAM: 1G
Firmware/APP Version: Android 9
Frequency of Occurrence: Always
Rooted: No
APP Name:
Please fix the battery optimization ... This gigantic 5000mah battery has been outlasted by others 3000 mah battery.... This is frustrating...
RAM: 1G
Rooted: No
APP Name:
0
Comments
Could you tell us how the battery performance problem appears?
Does the battery drain quickly? If yes, during use or in sleep mode?
Thank you
If you feel like the battery drains during using specific apps, we would suggest you test how much the app drains after using it for a certain time.
We would suggest you clear the background apps, and check how much battery is consumed from 100% after using the app for a certain time (e.g. 30 mins or 1 hour.)
Please show me a screenshot of the battery usage after testing.
Settings > Battery > Three dots on top right > Battery usage.
Thanks for your help
I visited the service centre to format mobile but they downgraded it to android 8 . Later mobile was having automtic update enabled which cause it to upgrade pie.
I request you to kindly escalate this issue and create a patch.
