Battery problem
After the pie update I found a problem in my pro m1 ,Now it's takes time almost 4 hours 0%-100%
Please give update to fix battery problem
Comments
  • I am satisfy with you mine also takes 4hour
  • I'm not facing that issue but I do noticed lots of bugs like the charging sound not working and the status bar is too snall
  • Hi luckymayur071,
    Now it's takes time almost 4 hours 0%-100% --> Does this mean charging the phone takes 4 hrs?
    Are you using the original 5V2A adapter?
    Were you using the phone the same time while you were charging?
    Could you check how long it takes when charging from 0% to 100%, while the phone is in sleep mode, without using the phone?
    Thank you :)
  • davidlaw2275 posted on 2019/6/2 17:27
    I'm not facing that issue but I do noticed lots of bugs like the charging sound not working and the ...
    Hi davidlaw2275,
    Have you enabled "charging sounds" in Settings > Sound > Advanced > Charging sounds?
    If the problem still appears, please tell me does it appear every time? Or what specific moments does it appear?
    Thank you :)
  • Jei_ASUS posted on 2019/6/3 04:51
    Hi luckymayur071,
    Now it's takes time almost 4 hours 0%-100% --> Does this mean charging the phone ...
    I just checked it's takes 4 hours and when I uses the phone while charging it's not charge,,like 33% while using after 1 hour 29%
