Incredibly shortened battery lifespan and generating ton of bug reports
Model: ZE620KL
RAM: 6G
Firmware/APP Version: 90.11.162.50
Frequency of Occurrence: Permanent
Rooted: No
APP Name:
After a second last update the phone started generating ton of bug reports which cannot be opened. Somethimes the report gets stuck and disappears only after restart.
Also the memory usage is getting worse and worse, now it lefts only 1GB free which is impossible. How could Pie run on slightly older phones with 4GB RAM then? This goes with incredibly shortened battery lifespan. Month ago I got day and half from one charging with heavy use. Now it medium use of the phone I get 10 hours and the baterry is dead, doesn't even make it through day. That is a huge problem that needs to be fixed.
RAM: 6G
Rooted: No
APP Name:
0
Comments
Good day.
Do you mean the "Bug Report" keep uploading in the background?
If yes. I've texted you by PM, please kindly check it.
Hi bharathkcena,
Good day.
Have you ever installed a log tool of Asus?
