Rear camera problem with flash light
ifthakher668ifthakher668 Level 1
edited September 2020 in ZenFone 5 Series
Model: ZE620KL
RAM: 4G
Firmware/APP Version: Latest
Frequency of Occurrence: Always
Rooted: No
APP Name: Camera
In night when I took pictures with flash light on phone. The picture not clear,it's blurry and focus not work properly and picture it's very bad .
Plz improve it.
Comments
  • Hi ifthakher668 ,
    Good day.
    The low light may also affect the focusing speed, I would suggest you try to focus manually for a check.
    And I also suggest you check on this matter in the brightness environment.
    Thank you. :)
  • Solve this focusing speed on low light.
  • Fathom this concentrating speed on low light.
  • I think a night sight like mode would solve the problem
  • Last edited by Emilee_ASUS on 2019/4/19 11:16
    Hi ifthakher668,
    Sorry for not making my explanation clear,
    As my previous reply, the low light may also affect the focusing speed and the camera's aperture is rather small than the main camera. If your camera is currently on the version 4.2.9.0, I would suggest you try to restore the camera and focus manually for a check. (settings > apps & notifications > see all apps >camera > storage & memory >clear storage & cache)
    I've tested and enabled the flashlight, use auto and pro mode to take a photo in the low light environment.
    But I don't find out focus not working problem in the latest version.
