Charging Problem
edited September 2020 in ZenFone 5 Series
My fast charging not working properly
Comments
  • Can u plz solve my problem of my phone charging (zenfone 5z) problem
  • My phone sms g charge problem Asus Zenfone 3s max
  • Hi All,
    Good day.
    Could you please kindly help me update the system to the latest WW-90.11.162.50 for a check?
    (settings> system > system update)
    If this problem still appears, please kindly let me know.
    Does this problem appear if using the stock adapter to charging?
  • I had a same problem.
    The update WW-90.11.162.50 has fixed my mobile fast charging issues. Kept under monitoring..
    I have observed another issue like Home icons are hidden, need to restart the mobile to fix the issue temporarily.
    Please fix this also.
    Regards,
    Jagan
  • Hi JaganR,
    Thanks for your message.
    For the icons on the home screen are hidden, we've reported this problem to our tech team.
    Thanks and have a nice day.
  • JaganR posted on 2019/4/8 17:21
    The update WW-90.11.162.50 has fixed my mobile fast charging issues. Kept un ...
    Hi JaganR
    Good day.
    I would suggest you can refer the below video for the short-term solution first.
    https://www.asuswebstorage.com/n ... 61BD60108550F369F1Y
    Hi JaganR
    Good day.
    We've released Asus Launcher apk and update the Asus support page.
    Please kindly download the new Asus Launcher apk to fix this problem first.
    https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZS620KL/AsusLauncher_5.5.2.43_190410.apk
