wifi/system problem
Model: ZS600KL
RAM: 8G
Firmware/APP Version: -
Frequency of Occurrence: 1
Rooted: No
APP Name: streaming Arena of Valor
bought the phone few days ago and have been playing a lot on mobile network so far. been happy about it.
But now the reason I bought this.... I wanted to stream to twitch. first of all I think my mobile network wasnt fast enough and AoV mentioned about stability problem. So I closed the stream, changed over to wifi and went again. This time when I turned the stream on my mobile phone went back to stone age. every movement control was like 5 seconds after making it and no picture came to twitch ether. AoV was showing very fast connection but phone controls- froze.
any tips what could cause this?
-- Kim
RAM: 8G
Rooted: No
-- Kim
Comments
Hi kim.traskelin,
Thanks for your feedback.
Could you tell me your Arena of Valor version?
Does any error message appear when the problem happens?
Could you show me a short video of the problem?
Please upload to a cloud storage website and share the link to us. You can try ASUS WebStorage: https://www.asuswebstorage.com/navigate/
Please try resetting your network settings and try again. (Settings > Connections > More > Network settings reset.)
If the problem still appears, please tell me the brand and model of the WiFi router that has this problem.
Have you tried connecting to a different router?
Do other phones connected to this same WiFi have the same problem at the same time?
Please show us a screenshot of your WiFi information.
(Settings > Network & Internet > Wi-Fi > tap on the WiFi already connected to access Network info)
Thank you and sorry for the inconvenience caused.
Router is zyxel WAP6806 and the problem is with that. not sharing all the info but signal strength is good, frequency is 5 Ghz and security WPA2 PSK.
this router works just fine with my iPad , Mac book pro and couple other devices, no problem, but not with this phone.
ok, the positive thing, I tested with my other router, yeah, I have 3 different ones for different usages
so the question is now that is it so that ROG Phone just doesn't work with 5 GHz frequency?
Hi kim.traskelin,
Does other apps work okay when connected to this 5 GHz WiFi router? Could you use the Internet normally?
Could you show me a screenshot of the error message or a short video?
Thank you for your help
well I broke the phone allready and waiting for replacement. But there was no error messages or something like that. If you don't guys understand what means that game doesn't respond to controls immdiatly but makes the stuff after 3-5 secs. It mainly showed up in games because they are apps that needs fast responding for controls. If you guys don't understand what I'm talking about you really shouldn't be making game phones
-- Kim
Hi kim.traskelin,
Thank you for your reply.
We have tested our 5GHz router and it is able to stream Twitch on Arena of Valor and PUBG.
If the problem is still appearing again, we may need some more information.
Sorry about the inconvenience, but this could help us understand the situation more clearly.
You can let me know if the problem is still appearing again. Thank you
