Battery drain
edited September 2020 in ZenFone 5 Series
Model: ZE620KL
RAM: 1G
Firmware/APP Version: -
Frequency of Occurrence: -
Rooted: No
APP Name:
Hello after the update to pie the ZenFone 5 drains battery really fast plz fix
Comments
  • Hi Snowjet,
    Good day.
    Are your firmware version currently on WW-V16.0610.1812.58?
    Do you mean your phone battery consume soon when standby or in use?
    Thank you
  • Yes I am
    After the update my battery goes empty really fast
    Before I did easy 8 @ 9 hours normal use on work and got 73 % left
    Now after update its 23 % after work or the phone is empty
  • Hello, I have the same problem after updating to Pie. My firmware version currently on WW-V16.0610.1812.5
    The battery goes empty fast. With the same use at this time I am 82 % instead of 92 %
    What can we do ? Always checked the options etc in settings.
    Thanks
  • Im suffering the same. I charge my phone to 100%, left it on stand by and by the night it consumes 8 to 9%.
