SOLUTION !!! Possible solution for call of duty on Android 10 so that it no longer hangs
Go to developer options and go to Game driver preferences and selec system graphics driver and supposedly the game would no longer cause problems ?
1
Comments
Hi Gusta_CM, did you tried?
What other things on the phone change with that option?
This was not a working solution for me yes I too found and tryed you want best fix I've come to find by trial and error downgrade firmware to 9 from Asus website then you also can modify xmode performance aswelll as high frame rate in-game and medium graphics if you seam to lag with network drop fps down one more notch for stability with fps
Check Xda for info on downgrade proccess
