GPS location problem android 10
anubhav61anubhav61 Level 2
edited September 2020 in ROG Phone 2
I am in india.. Kanpur. Right now. BT GPS after android 10 always move to this place outside of India and stuck here.. Try hard in map sometime back to India.. BT most of the time my location outside of India.. Anyone also facing same problem.. Any solution?
Comments
  • Try long press the maps app -> click app info (circle with an i) -> Storage & cache -> Clear storage. This will reset that app.
    If that doesn't help, then I'm afraid that you will need to reset your device. You may try the other reset options before the factory reset but I don't believe they will help.
