Crazy battery drain(No heavy Usage at all).
Akash PratapAkash Pratap Level 1
edited September 2020 in ZenFone 6
I use phone normally. Not any game play or heavy apps used and still end up getting SOT of around less than 4 hours.
I have shared the usage statistics.
If I start my day at full charge in the morning then by 10 in the night my battery percentage remaining is usually 9-10% and if I don't put it in charge then my alarm won't ring next morning because it switches off in the night sometime due to empty battery.
Mobile network standby battery consumption is 1% (Refer screenshot shared).
Comments
  • sedl23sedl23 Level 2
    Looks like u need to force stop psiphone pro and Google play services
    My battery life is ok could be a bit better but I Google and Google play services are hurting my battery but at 4 hrs sot I'm at 51% battery right now
  • Psiphon pro and Google Play services are using only 2% & 3% battery drain which won't save me enough to really impact my SOT.
  • Let's just start off saying that I don't trust the battery usage service in Android. I'm not saying that psiphone pro is the guilty app but just because it's reported as 2% doesn't mean that it's 2%. It can be 30% too. As you can see in your screen shot there are 47% unaccounted for.
    Go to system settings -> battery -> powermaster -> auto-start manager and prevent all the apps you don't need a notification from to auto start.
    After this go to system settings -> advanced -> Mobile Manager -> Memory cleaner -> Turn on Super Clean mode -> enter app list and uncheck any app that you must get notifications from -> go back -> open recent apps overview and press clear all.
    If you notice that you battery life has improved, then you have a battery draining app among the apps that are no longer allowed to start by itself. To find it, allow a couple of extra apps to get auto-restart permission every day until you notice the battery life going down again. Now it's easy to narrow down which app that's guilty.
