ROG 2 Custom & Default sound/ringtone issue
michelangalomichelangalo Level 1
edited September 2020 in ROG Phone 2
I have added a custom ringtone and now i don't see system sounds.
There should be a way to see system sounds without deleteing custom sounds. Attaching video to show the same.
https://us.v-cdn.net/6031231/uploads/008/WEOO7AO0KPEF.mp4 There was an error displaying this embed.
Comments
  • This is a bug. It's not supposed to look like that. I don't know how to fix it. You could try to go to settings -> apps & notifications -> see all xxx apps -> three dot menu in top right corner -> show system -> settings -> storage & memory -> clear storage. Maybe you need to do this for the "settings storage" app too. I'm really not sure if this will work and it will reset a lot of your settings but it's still better than doing a full factory reset.
  • I really don't want to impact any settings. Can you kindly forward this bug to the dev team so they can look into this.
  • We can log your device. Without anything to go on, we will never find this bug.
    I can send you a PM with instructions
  • Our dev team has looked at your log file and can confirm that this bug is due to that you've installed a xiaomi file explorer which is not compatible. Uninstall it, remove the custom sound and add the sound using our file explorer. Hopefully your sounds will start working again.
