[FIXED] Battery stuck at 53% || Power button + Volume(+) button = Soft reboot
sixth_pr1m3sixth_pr1m3 Level 2
edited September 2020 in ZenFone 6
Phone started having random reboots 24 hours back. Phone used to reboot very frequently, 4-5 times in 30 mins.
I kept the phone turned off over night and in the morning the phone was dead, it won't even charge.
I somehow manged to turn it on after 30 mins, still had the same reboot issue.
I went to recovery mode and installed the Android 10 stable from SD Card, but didn't fix the issue.
From recovery mode I did factory reset the phone and now phone is working fine without any reboot issue.
Now the issues are:
1) Battery is stuck at 53%, won't change no matter what.
2) If I press Power button + Volume(+) button for a second, the phone does some sort of soft reboot.
Comments
