Camera flip problem
ranathpodemranathpodem Level 2
edited September 2020 in ZenFone 6
Camera is not flipping up it shows "unable to flip camera" and when i try to calibrate camera it shows " camera can't flip"
But there is nothing obstructing it. Do i have a solution
Comments
  • And it is going down while flip but not getting up. Is it a mechanical problem should i go to service center or it will settle by update.
  • Try to clean your screen and remove any case you have. Some glass screen protectors may also be problematic.
  • Yeah! Bro got it thanks for the response
