on 10-14-2019 02:25 AM
Please follow the methods below to solve the battery power drains fast problem:
1. Activate power saver and battery saving mode.
Enable Smart saving and select your preferred mode in Settings >> Battery >> PowerMaster >> Battery modes.
Note: Super saving mode is recommended when other modes do not meet your requirements.
Please note this mode will disable the network connection when the device is suspended and will not instantly receive messages from instant messenger apps.
2. Disable the network connections that are not used
Disabling the network connections that are not currently used, such as Wi-Fi, Location, Network data usage, Wi-Fi Hotspot, Bluetooth and GPS etc.
3. Stop Background apps.
Some apps which automatically start in the background may not only occupy memory, but also cause system lag and drain the battery.
By managing these auto-start apps, ASUS PowerMaster helps release more memory, improve system performance, and save power.
Settings >> Battery >> PowerMaster >> Battery-saving options >> Stop unnecessary apps.
4. AI Boost
Swipe down from the top of the screen to reveal the menu. Select Quick Settings and tap “AI Boost” to allocate the device's resources to optimize system performance.
5.Disable Accounts auto sync.
Disable individual sync function in Settings >> Accounts >> Automatically sync data.
6. Repair Option.
If the steps above do not help resolve your problem, please contact ASUS Product Support
Other options in Settings:
Adjust device Sleep Time.
Remove one of the installed SIM cards if it has not been used for a long time
Disable Auto-rotate screen.
Use a darker wallpaper.
Remove widgets that are not used on the home screen
Restart the device.
Play Store: Open and tap upper-left menu icon .
Google Now cards: Turn off .
Adjust brightness of display: Settings >> Display >> Brightness.
Close Live Wallpaper.
Tap Recent Apps key and perform .
