Wifi disconnecting problem
paras0710
Rising Star II
Hi i am having this issue since day 1 with Asus 6z is that wifi connection keeps disconnecting itself randomly and the culprit i think is dual band wifi with same SSID. I have mi router pro and both bands have same SSID and i think Asus 6z is unable to switch between them swiftly and make this problem. All other devices in my home also my previous phone did not have this problem.
I once reported this but i wasn't sure if it is my device or everybody facing the same issue so i keep using it as its is. But now its started to annoying me once i was making some online payment and in middle of payment gateway wifi disconnect and money deducted without redirecting to merchant. A week back i was trying to post this problem here on this forum but when i clicked post the wifi disconnect and it did not posted and everything i wrote got clear so i didn't post it back then also.
I cannot record this on video as it is random (i just checked while writing this it disconnects again and connect itself after 5-10 seconds) when disconnection happens i have to manually connect it or wait for atleast 5-15 seconds to connect automatically.
BTW i already tried reset network from settings
12 REPLIES 12
kikoly
Hall of Fame II
Is your wifi channel 2.4GHz or 5GHz? Is there a disconnection problem if you use another one?
paras0710
Rising Star II
kikoly
Are you asking if i am using 2.4 or 5 GHz ? If yes then already mentioned i am using dual band router with both bands have same SSID/wifi name. If you are asking which channel i am using then i am using channel 1 on 2.4 GHz with 40mhz bandwith and 36 on 5 GHz with 80 mhz bandwidth.
All device switches to band with strong signal automatically and i think Asus is have problem doing so. I think if both bands have different name it is working ok( i will check it again) but i dont want to name both differently even router itself have option of doing so so that is not something one must not do.
kikoly
Hall of Fame II
paras0710
https://zentalk.asus.com/en/discussion/comment/17525#Comment_17525
Don't use the same SSID / wifi name? Will also disconnecting?
paras0710
Rising Star II
kikoly
https://zentalk.asus.com/en/discussion/comment/17528#Comment_17528
I think not but i will check and reply after that.
