3 weeks ago
Model Name: Asus ROG phone 6D ultimate
Firmware Version: 34.0804.1204.56
Rooted or not: not rooted
Frequency of Occurrence: always
Hello, i wanted to see of anyone has this problem, when i use apps on full scaling, the edges are not visible, so i only see a part of what should be displayed.
I m using Android 14 lates version and tried to reset the display on the settings menu as well to turn off and on the phone.
On the picture i mark the bottom right side where the version of the app is cut in half by the edges of the screen. This problem happen with every app.
3 weeks ago
Hi!
Could you maybe send another picture of another app doing this?
3 weeks ago
2 weeks ago
Mattias_Asus, did you see the other imagine that i posted ?
a week ago
I think it might be your screen protector or temper glass, did you remove it and checked?
